Activity Forums AJA Video Systems T-TAP issue
  • T-TAP issue
    Posted by John Watts on July 11, 2021 at 12:10 am
    I’ve been using a T-Tap starting with FCPX only and it worked fine.
    Had to add Premier Pro and the T-Tap would work on both apps, switching seemlessly.
    However, that did not last long. Now, T-Tap works fine on Premier and doesn’t work on FCPX.
    In fact, if my T-Tap is even connected, FCP will not open up at all, just a pretty beachball.
    Any ideas?
    John Watts replied 5 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
