Activity Forums Apple Final Cut Pro Legacy System Specifications
  • System Specifications
    Posted by Benjamin Devoe on May 23, 2009 at 9:14 pm
    Hello CC Gurus,
    For editing in FCP, what is more important for ensuring a seamless (fewer dropped frames/better quality) editing environment on one’s computer: Memory (RAM) or Processor speed. I’m choosing a new platform for editing, and I need to know which configuration I should spend more $ on.
    Ben
    Arnie Schlissel replied 17 years, 4 months ago 4 Members · 4 Replies
  • Thaxter Clavemarlton
    May 23, 2009 at 11:43 pm
    Which is the most important leg on a three-legged stool?
  • Benjamin Devoe
    May 24, 2009 at 2:58 am
    So what you’re saying is, neither memory nor processing speed is anymore important than the other in all circumstances?
    Cryptically Yours,
    Ben
  • Rafael Amador
    May 24, 2009 at 6:17 am
    If you get the bigger processor with all the RAM that you can mount but you don’t install a good GPU, you won’t go to far.
    All the FC’s Fxplugins, Motion, Color etc are GPU dependent.
    rafael
    http://www.nagavideo.com
  • Arnie Schlissel
    May 24, 2009 at 6:51 pm
    A faster drive array will provide the most obvious benefit to RT playback (and it will open you up to larger frame sizes & less compressed codecs).
    But all of the critical subsystems of CPU/GPU/memory/drive system are of equal importance in the end.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
