Activity › Forums › Avid Media Composer › system requirements
  • system requirements
    Posted by Jack Entonces on February 23, 2008 at 8:47 am
    I am going to upgrade from Avid Xpress DV to AX Pro.
    Can someone please tell me what are the system requirements to run Xpress Pro
    as efficiently as possible?
    If anyone knows a link that will give me this information,
    I would really appreciate it.
    thanks
    Accountfrozen_needs_realname replied 18 years, 7 months ago 4 Members · 6 Replies
  • Jon Zanone
    February 23, 2008 at 12:19 pm
    System specs here:
    https://www.avid.com/products/xpresspro/specs.asp
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Jack Entonces
    February 23, 2008 at 8:36 pm
    thanks, i saw that, but it mostly tells me what systems to buy that are compatible.
    Currently, I have Xpress DV in a PC. Intel Pentium 4, 2.0Ghz,/256K/400MHz,
    Windows Professional SP, 1Gig ram, Matrix Millenium G550 AGP Dual 32MB Card.
    I have three drives, one is boot drive, other two are for storage.
    Can anyone tell me if these specs that i now have will work with Xpress Pro.?
    or do I need to get something more powerful? I’d rather not spend the money,
    but if I have to, i guess I will.
    thanks
  • Jon Zanone
    February 24, 2008 at 12:19 am
    You can buy whatever you want. But in order for XPress Pro to work properly, you need to buy whats on the list. Yes, its expensive. But if you are making money off this system, it’ll pay for itself.
    Jon
  • Jack Entonces
    February 24, 2008 at 5:21 pm
    thank you for answering my question.
  • Scott Cumbo
    February 25, 2008 at 3:47 pm
    you can use a non-qualified system to run Avid, but you
    may run into issues. or you might not. Thats the trick, avid
    will only suport qualified systems. so you would be on your
    own if you have any problems.
    I’ve been running media composer on my system at home with no problems. Not only is it not qualified, but doesn’t even meet the minimum system requirements.
    quickly looking at your system specs, you may need a new
    video card. Avid wants nvidia cards, even an older 128mb card will do.
    There’s really no way to tell if you will have any issues
    until you load the software and try it out. I’m not sure
    if express pro has a downloadable trial ver. or not.
    Scott Cumbo
    Editor
    Broadway Video, NYC
  • Accountfrozen_needs_realname
    February 25, 2008 at 8:17 pm
    You will, at least, want to consider adding another GB of RAM for a total of two on the system.
    I presume you have a typo and meant you have a Matrox video card. My understanding is that Avid really does not like Matrox cards at all. They particularly like and want the NVidia Quadro cards. I think it has to do with the way the card handles instructions, particularly in hardware as opposed to a software layer.
    Or some techno-babble similar to that which I admit I don’t fully comprehend. I’m gonna go align the plasma injectors in the warp core pre-sequencers now. . .
    Jon
    _______________
    Lack of preparation or organization on your part does not constitute an emergency on my part.
