Activity Forums Apple Final Cut Pro Legacy System Maintenance Question
  • System Maintenance Question
    Posted by Ally Shore on June 7, 2010 at 6:00 pm
    Just a general question to the room. I’ve always been an “if it’s not broke…don’t mess with it” kind of gal. However, many people have said I should do periodic system & preventative maintenance on my computer. I have about a 10 day window of down time for cleanup. What is the forums general opinion on Final Cut Pro system maintenance? Do you wipe your main drives and reload everything? Do you run basic diagnostics? Do you reload a clean system? Just curious.
    Ally
    Craig Sawchuk replied 16 years, 3 months ago 8 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    June 7, 2010 at 6:17 pm
    [Ally Shore] “Do you wipe your main drives and reload everything? Do you run basic diagnostics? Do you reload a clean system? “
    If nothing at all is broken then I say don’t do a 100% reinstall. The following is a very basic routine to follow when you’re just doing “routine maintenance.”
    1) Repair Permissions on your system drive
    2) Run Disk Warrior on all drives
    3) Run Applejack using “applejack AUTO restart,” which will do many things, but above all cleans out all Unix caches systemwide.
    4) Go get a beer and chill out.
    If you have enough storage to copy all media while you reformat your main storage, that’s always a nice luxury, but it’s not completely necessary if Disk Warrior has its way.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Michael Sacci
    June 7, 2010 at 6:19 pm
    On going maintenance I use 3 apps routinely
    For system I use these about every month
    Cocktail, this cleans out all the caches and logs (think it is about $30 download)
    Diskwarrior, rebuilds finder directory
    For FCP
    Preference Manger (same people that make FCS Remover) both are must have apps.
    For new installs always clone your existing drive, that way there is no risk. Then reform your system drive and update system, than FCS, update that, then install current drivers and other software.
  • Jeremy Garchow
    June 7, 2010 at 6:32 pm
    [Ally Shore] “Just a general question to the room. I’ve always been an “if it’s not broke…don’t mess with it” kind of gal. However, many people have said I should do periodic system & preventative maintenance on my computer. “
    I would stick with if it ain’t broke, don’t fix it.
    If your car is running fine, do you take it in to the shop?
    Maintenance tools are fine, but don’t use them until something isn’t running correctly.
    That’s my opinion anyway.
  • David Roth weiss
    June 7, 2010 at 6:37 pm
    Applejack and Cocktail have many similarities and achieve many of the same results, but AppleJack is free, and because it boots and runs under its own Unix subset rather than under OSX, it is able to clean some system caches that Cocktail can’t access.
    BTW, for the faint of heart or those who are timid when it comes to running these types of tools, in five years of use, I’ve never once experienced even a single issue created by Applejack, and I’ve used it on every type of Mac available running under every version of OSX.
    David Roth Weiss
    Los Angeles
  • John Fishback
    They also make FCS Maintenance Pack. While I agree with both David & Michael and do the same kind of monthly maintenance, sometimes there are specific issues one of the programs in FCS MP can address, like a corrupt project or media.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.2, Motion 4.0.2, Comp 3.5.2, DVDSP 4.2.2, Color 1.5.2)
  • David Roth weiss
    June 7, 2010 at 6:58 pm
    [Jeremy Garchow] “If your car is running fine, do you take it in to the shop? “
    Absolutely!!! You change the oil in your car don’t you Jeremy?
    Routine maintenance using the tools I’ve mentioned above involves no danger, so why wait until your system breaks? By then it may be too late.
    David Roth Weiss
    Los Angeles
  • Jeremy Garchow
    June 7, 2010 at 7:02 pm
    I do, when it’s time to change the oil, yes.
    I just don’t like Disk Warrior is all. It’s done more harm than good in my experience. Cleaning caches is fine, but not necessary, trashing prefs is good, but only when something isn’t going correctly.
    I’m just saying, if it’s running fine, there’s nothing to fix. That’s my opinion and experience.
  • David Roth weiss
    June 7, 2010 at 7:09 pm
    [Jeremy Garchow] “That’s my opinion and experience. “
    I understand. Not one of us can convince the other if our own anecdotal experiences convince us otherwise.
    Thankfully, my experience with all of these tools has been flawless, so I’m able to recommend them with 100% confidence. If that should ever change, I’ll be the first to report it right here.
    David Roth Weiss
    Los Angeles
  • Michael Sacci
    June 7, 2010 at 7:21 pm
    Cocktail is much prettier to look at :-). I bought the family license years ago and so far all the upgrades have been free. And command line tools scare me, I did like to see a UI.
    If it ain’t broke, it can easily be fixed.
  • Walter Soyka
    June 7, 2010 at 7:37 pm
    Whether you do system maintenance or not, your downtime would be a great time to make sure your backups are complete. Also, it’d be a great time to make a bootable clone of your main system drive to keep on-hand, just in case you experience problems in the future.
    Walter Soyka
