System low on memory
Posted by Erling Fenstad on August 8, 2009 at 9:36 pmHi!
I’m working on a 4.16 minute long HD movie in Vegas 9a.
When I try rendering it reaches around 60-70% until i get the message:
System low on memory….
Why does this happens? I got 8GB om RAM and and runs Vegas in 64bit…
Please help me!John Rofrano replied 17 years, 1 month ago 3 Members · 4 Replies -
Erling Fenstad
August 8, 2009 at 11:41 pmIt’s the same issue as here: https://forums.creativecow.net/readpost/24/896574
Norman Willis
August 9, 2009 at 7:03 pmHi Erling.
Lots of people are having rendering issues “Low on memory” in VP9.0 and 9.0a. Editing WMV files seems to exacerbate the issue, but others have this problem even without .wmv. (I had problems with AVCHD in 9.0, but 90a resolved my problem.)
I still have to set Dynamic RAM preview to 0 (I just leave it there), reboot the machine (to defrag the paging file), close all other unnecessary applications, and kill Anti-virus/Internet Security. Then it seems to render for me. However, there are four or five other folks on this forum actively experiencing the same issue. One of them may be a problem related to using a Dell (which has non-standard parts), but the others report that this error is new to them with 9.0a (i.e., they did not experience it before).
Another thing you can do is to check your paging file, and set it at static (1.5 times the size of your RAM, both beginning and maximum settings). It has also been suggested that reloading Windows may help.
Also, most important is to report the problem to Sony, https://www.custcenter.com/cgi-bin/sonypictures.cfg/php/enduser/ask.php, so their software engineers can work on a bug fix for 9.0b. Please give them as much information as you can.
I hope this helps you.
Norman Willis
http://www.nazareneisrael.org
servant@nazareneisrael.org -
Norman Willis
August 9, 2009 at 7:03 pmHi John.
This issue seems to be coming up again and again. Is there some way to make a stickie in this forum, for rendering issues with VP9/9.0a?
Norman Willis
John Rofrano
August 9, 2009 at 8:02 pmStickies would be nice but this forum doesn’t have them. 🙁
~jr
http://www.johnrofrano.com
http://www.vasst.com
