Activity › Forums › Apple Final Cut Pro Legacy › system for working with 3/4″ tapes
  • system for working with 3/4″ tapes
    Posted by Aric Walken on January 16, 2009 at 6:15 pm
    I have come into a project that has a good amount of the footage shot in the 1980s on 3/4″ tape. I am trying to figure out the best way to 1) back up this footage–there are a lot of interviews with important historical figures and 2) begin editing
    At the moment I am working on a G5dual 1.8 GHz but I might end up buying a new system because this computer is tied up with another project and is pretty old anyway.
    So I am looking for advice on what equipment to purchase. I have some rough ideas about ways to go, but want other input. I was thinking about a new G5 and maybe a black magic card (this is where I really need some advice) that would enable me to hook a 3/4″ deck up.
    And what about backing these tapes up for posterity? I assume that maybe digibeta is best, but if I can’t afford that what are other options? Should I back up to harddrive, tape or both? If I backup to say, DVCAM then there is a compression loss, right? What about to regular beta from 3/4″?
    Would a black magic work to hook up to digitize uncompressed 3/4″ and to transfer to beta (if that is what I decided to go with)?
    A second question is about a production monitor. I used to have a Sony Trinitron. But now on B&H it seems they aren’t made any more. Can someone recommend a decent production monitor for editing with good color? Are they not making CRTs anymore? For some reason I’m afraid of the LCDs because I feel the quality isn’t as good for color. Am I just superstitious?
    Sameer Thaver replied 17 years, 7 months ago 8 Members · 10 Replies
  • 10 Replies
  • Michael Gossen
    January 16, 2009 at 8:31 pm
    Wow, you cover a lot here. If I may, I think cloning your tapes to DigiBeta makes the most sense for the future, and honestly if they are that important, have it done right. That does a couple things for you. You can then digitize off the DigiBeta to edit, and preserve the tapes in a good future resistant format.
    As far as the computer, when you say new G5, do you mean a new Mac Pro? I would also suggest a Kona3 Video Card. I think it is the most versatile. Many Blackmagic cards are very good too, I think this comes down to what one wants to spend on it.
    You can still find new BVM CRT’s. But I have a PVM-14L5 as one of my CRT’s and I really like it. There are several on ebay right now. Again, I think it depends on the investment. Good Luck.
    Michael Gossen
    Helium Digital Media
  • Michael Gossen
    Michael Gossen
  • Chris Poisson
    January 16, 2009 at 8:33 pm
    Aric,
    Even if you can find a decent 3/4 player, your tapes are so old they may suck, but then, 3/4 sucked to begin with. Digibeta would be the best backup, but what a cost to backup something that is so awful to begin with. If any of your footage is decent, I would just keep digital copies, uncompressed or ProRes, NOT DV.
    To capture 3/4 to uncompressed, you’ll need some kind of SD card, BM makes a pretty good cheap one. You may need one that’s PCIE if you get a new machine.
    To copy the tapes to Digibeta, you don’t need a card.
    CRTs are available on eBay, but there are some decent LCDs and plasma monitors, but they can be pricey. There are a boatload of threads on monitors in the archives here.
    Have a wonderful day.
  • Bjørn Holmgren
    January 16, 2009 at 11:17 pm
    I would try to get my hands on a TBC (Time Base Corrector) for the 3/4″ player. Both Digibeta and capture cards can be unforgiving about horizotal timing in the video signal, resulting in wavy vertical lines in captures from analog tape.
  • Rafael Amador
    January 17, 2009 at 3:18 am
    In the year 2009 I wouldn’t go from a tape solution to another tape solution.
    But if I would need to go to tape probably I would go to DV50.
    Good enough to transfer U-Matic material, that in the end is like an improved VHS.
    BetacamDigital would be very expensive and you won’t see much difference.
    As Biorn suggest, get your self a U-Matic player with TBC.
    Then any video card with Composite Video IN will do de job.
    Cheers,
    rafael
    http://www.nagavideo.com
  • David Bogie
    January 17, 2009 at 5:22 pm
    Dubbing 3/4″ to a superior codec without enhancement and time base stabilization is pointless. Go directly to DV or even to VHS.
    There is a very good possibility you will not be able to dub these tapes because the oxide is going to peel off. try to locate a non-SP 3/4″ machine. The SP models used much more head-to-tape penetration and tension.
    bogiesan
  • Bob Flood
    January 18, 2009 at 11:05 pm
    Hey
    Little late to the game, buuuut
    EBAY!!!
    find yourself a BVU 800. the most reliable and stable 3/4 VTR made. If your tapes are Regular U MAtic, (as opposed to SP) it will handle the tapes nicely
    AND
    You should’nt just look for any tbc, but a Fortel TBC. They had special circuitry designed to do Time base correction on the 3/4 video signal after converting from “color under”, which was a limitaion of the format and caused rapid generation loss, even over one or 2 gen’s.
    Using the BVU800 to play back the tapes, and feeding the TBC via the Dub Out, will give you the best possible reproduction of the video signal. THe Fortel should have an S video out as well as Composite Video. By feeding the S video into a Digitbeta, BetaSP, or Capture Card, you avoid the signal becoming encoded, and preserve the quality even further.
    and i would go to a Digital tape format, either DVCPro50 or Digibeta,
    DVcam would be a bit of a loss.
    BTW, there a quite a few “Video Cleanup” plugins for FCP. If the video is really bad, those can help.
    hope this helps
    ironically, this gear would have set you back 20 to 40 grand back-in-the-day, but you can probably assemble the whole kit for 2 to 3 grand.
    They usually go under the name Fortel Turbo.
    “I like video because its so fast!”
    Bob Flood
    Greer & Associates, Inc.
  • Sameer Thaver
    February 16, 2009 at 5:37 pm
    Hi!
    Actually, I’m working on starting a TV program soon & will be receiving something along the lines of 12 years worth of items all shot on 3/4″ tape. I’m REALLY nervous about these digital broadcast rules which are to supposedly shut out formats like Beta SP.
    I wanted to ask you a few questions relating to this broadcast issue and about dealing with these 3/4″ tapes…
    1) Will feeding my tapes into the computer and turning them into Quicktime files be enough to deal with this digital broadcast “monster” on the way? Or will I have to set up a different conversion setting such as DVC-PRO to make it good for broadcast in the future?
    2) I’m currently in the process of working with a friend to turn some of his 3/4″ tapes into DVDs for the market… because the TV producer he was working with at the time had a love for recycling tapes, one of them has some dropouts (not major) but they cause the video to briefly go out of sync by the odd frame or two. Normally, when I face issues such as clogged tapes, I take them to a special place where they clean off any loose oxides which makes the tapes play like new. Should taking that tape to this place fix the problem?
    3) To do these transfers, I’m currently using a Sony VO-9800 (3/4 SP), one of the tapes I using plays like a dream except in one spot (40 mins in) where the tape makes a couple of minor shifts (which affects the digitizing slightly). I also have a VO-2610 sitting in my garage (perfect condition, except for the stop button needing replacement), would bringing in that machine, scrubbing up the heads & digitizing the tape in that machine fix the problem?
    4) I read your mentioning about tape clean-up plugins for FCP, I’m currently using FCP 5.1, would those plugins be available for my version? How can I find them & what in fact do these plugins do?
    5) Earlier, I mentioned these old tapes coming to me pretty soon, the majority of them date between 1978-1991 and are in very good condition. Is there a way these tapes can be made to look as if they had just been shot yesterday?
  • Bob Flood
    February 16, 2009 at 9:28 pm
    I am not sure waht you mean? We find the problem isnt so much resolution, but the aspect ratio, taking a 4×3 image, and putting it in a 16×9 format.
    If you mean digital video, then yes, but you need to choose a format thats better than DV, such as dvcpro50,
    Have you gotten a TBC for the VO-9800? the capture cards are not powerful enough to clean up the sync signals off tape. A time base corrector aka TBC does just that.
    without a tbc, a hefty drop out can cause you to lose picture sound sync.
    With a TBC, all you get is a line across the picture, and if the TBC has a good dropout compensator, it will just look like a line of video. (which may not be ideal, but will look better than the actual dropout.) I cant say whether burnishing the tape (the “place” you speak of) will help. Personally i would not.
    Do you mean a VO-2600? a top loading machine? the machine you are using now is better.
    the minor shifts will not affect your digitizing once you have a TBC
    I am using the CHV repair collection. google “video noise removal”
    if you can cut out the paisly shirts, bell bottom pants, and shoulder pads, sure! 🙂
    Creatively, There are 2 things you can do with old footage, clean it up, or make it dirtier.
    You can try and remove as much of the undesireable artifacts as possible, using methods you and i have talked about. they will never look like they were shot yesterday, but they will look as good as they can
    OR
    you can do trickery to make it look even more grungier than it already is. Run it through a monitor and re shoot it. Put some color and noise filters on it, stuff like that.
    hope this helps
    Bob Flood
  • Sameer Thaver
    February 16, 2009 at 11:22 pm
    Another question just came into my head Bob…
    The tapes I’m converting now were shot on ch.2 mono & in my FCP the first thing I do is join the two channels. The tapes are of South Asian music (for the DVD), how can I turn the audio into something good for disc such as 5.1 surround for example?
