Activity › Forums › Apple OS X › system extension message when boot up computer
  • system extension message when boot up computer
    Posted by Raju Bhai on September 23, 2006 at 5:27 pm
    i’m using a PowerBook G4, 1.67 ghz, (no intel).
    i first tried installing Avid (no Mojo) last week with the dongle in the USB port when i was on OX 10.3.9 and it said error installing. So I called Avid (it was during the week so i was able to talk to them), and she said the problem was i needed to upgrade to OSX Tiger. So I went ahead and purchased/upgraded to Tiger and re-installed Avid. Maybe i should have checked to see if the Avid (though not working) was already installed and to de-install first. But i didn’t. (although i doubt that’s the problem). And now it says:
    The system extension
    Chuck Reti replied 20 years ago 3 Members · 2 Replies
  • Simon Carlson-thies
    September 25, 2006 at 1:43 am
    you have a kernel extension problem you need to replace the bad ktext file…
    -Simon
    Simon Carlson-Thies,
    Digital Light Graphics And Animation
  • Chuck Reti
    September 25, 2006 at 4:54 am
    [raju] “It sounds like a problem with Mac OS”
    It sounds more like an Avid (or other third party)-installed kernel extension may have gotten lost in the new OS install process
    (I don’t have “DigiDal.kext” file on any non-Avid Mac I use, so I’m guessing it’s not part of an OS X install).
    When you installed Tiger, if you did an “Archive and Install,” which creates a “Previous System” folder, it could be hiding in there, and easily dropped back into the correct folder (administrator password required).
    Otherwise a re-install of Avid might have to do do the job.
