Activity Forums Adobe Premiere Pro System Config Advice
  • System Config Advice
    Posted by Gautam Pandey on November 21, 2012 at 6:00 am
    Hi everyone!
    A little tight on budget, so being a little conservative with the config.
    Will probably upgrade as I get along.
    Any opinions on this config? I will be editing and outputting in HD with usually no more than 2 video layers and a graphic layer sometimes on the timeline.
    Also any advice on which video card to use? I’m on Blackmagic on my MAC right now, should I just stick with it?
    HP Z420
    Intel Xeon E5-1607 3.00Ghz 10MB 1066 4C CPU
    8GB DDR3-1600 ECC (4x2GB) RAM
    1TB 7200 RPM SATA 1st Hard Drive
    NVIDIA Quadro 2000 1GB Graphics Special
    Microsoft Windows 7 Professional Edition 64bit O
    Thanks!!
    Gautam Pandey
    http://www.riverbankstudios.com
    Edit: Just read about the Nvidia Quadro SDI cards. any good?
    Gautam Pandey replied 13 years, 9 months ago 6 Members · 11 Replies
  • 11 Replies
  • Alex Gerulaitis
    November 21, 2012 at 10:24 am
    Don’t use 1607 – slow memory access. E5-1620 minimum.
    Upgrading to 16GB RAM isn’t a lot more money – and really worth it.
    My favorite base Z420: B2B94UT at $2199, also here fully configured.
    Ideally, get it graphics-less and add a GeForce GTX-660Ti for about $300 – much stronger than a Quadro 2000. If you must, go with Quadro 2000, but not the SDI version – Premiere Pro does not need or use the SDI part of it.
    What Blackmagic card do you have on the Mac and why do you need it?
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Dennis Radeke
    November 21, 2012 at 11:44 am
    Hi Gautam –
    I’d say you’re light on the RAM – you’d benefit from at least 16GB. If you’re trying to save a few bucks, you might see if you can configure the Z420 with a supported GeForce card instead of Quadro. THat said, the Q2000 is fine.
    Good luck.
    Dennis – Adobe guy
  • Gautam Pandey
    November 21, 2012 at 11:51 am
    Hi Dennis,
    Thanks for responding! Been doing some more reading and it seems the Geforce is the way to go and according some tests seems to work better with Premiere (even though Quadro does seem to be recommended on the site)
    here’s a few links which helped 🙂
    https://ppbm5.com/DB-PPBM5-2.php
    https://forums.adobe.com/thread/947698?start=0&tstart=0
    Any Advice on I/O cards. Blackmagic vs AJA vs Matrox 🙂
    Thanks a bunch!
    Gautam Pandey
  • Dennis Radeke
    November 21, 2012 at 12:09 pm
    All three of the card vendors are good. I’m Switzerland when it comes to i/o cards. They each have certain advantages.
  • Gautam Pandey
    November 21, 2012 at 12:10 pm
    hahaha… point taken 🙂
    Gautam Pandey
  • Walter Soyka
    November 21, 2012 at 2:12 pm
    [Gautam Pandey] “Any Advice on I/O cards. Blackmagic vs AJA vs Matrox :)”
    I am not Switzerland, so I can give a little more detail.
    AJA has legendary support that no other vendor can match. BMD has low, low prices and Resolve. Matrox has H.264 acceleration and external units that are easily portable, even without Thunderbolt.
    AJA has higher prices. BMD has questionable support and the cards can be finicky. Matrox is sometimes slow to update drivers.
    Search this forum for “capture card” and you’ll see tales of victory and tales of woe.
    I have had both AJA Kona and BMD Decklink cards here for years, and I’ve been happy with both. I have a Matrox CompressHD card that’s been a workhorse, too. Maybe I am Switzerland.
    Walter Soyka
  • Tom Daigon
    November 21, 2012 at 3:16 pm
    Im the USA (AKA outspoken) 😀
    I like the products and support of AJA.
    I do not like BMD based on my experiences with them. Cheap products with less durability then AJA. And tech support left a lot to be desired. Reports are they are still having problems getting good CS 6.03 drivers for their external monitoring hardware. AJA has had that nailed for the last month.
    Tom Daigon
    PrP / After Effects Editor
    http://www.hdshotsandcuts.com
    https://www.youtube.com/watch?v=DxPrG3WUyz8
    (Best viewed at 1080P and full screen)
    HP Z820 Dual 2687
    64GB ram
    Dulce DQg2 16TB raid
  • Gautam Pandey
    November 22, 2012 at 4:40 am
    Thanks Walter… that clears it up
    Think I’ll need to do a few corporate gigs and then go in for an AJA 🙂
    Gautam Pandey
  • Gautam Pandey
    November 22, 2012 at 4:42 am
    Hello USA 🙂
    Well that seals it! AJA it is!
    Gautam Pandey
  • Robert Brown
    November 23, 2012 at 7:13 pm
    Well you might get an angry reply from Grant on that post. But, I recently bought a BM Studio board for Davinci use and have to say on the Mac side it’s pretty crappy. Serious lag in PPro meaning the video out is several frames behind PPro’s monitors with no apparent solution. Also if you are doing something as basic as editing 24p into a 29i timeline, expect no video out from the source monitor. For whatever reason they are able to add pulldown on the Windows side with the same board and oddly sometimes it actually did this in Mac but I couldn’t figure out why it would come and go. I’d have to say the BM drivers are almost unusable for PPro in Mac at the moment.
    I have boot camp and found them to be better in Windows.
    Robert Brown
    Editor/VFX/Colorist – FCP, Smoke, Quantel Pablo, After Effects, 3DS MAX, Premiere Pro
    https://vimeo.com/user3987510/videos
