Activity Forums Maxon Cinema 4D Syntheyes Matchmove Scale
  • Syntheyes Matchmove Scale
    Posted by Samuel Hall on July 29, 2013 at 5:51 pm
    I’m primarily an After Effects artist so my knowledge of C4D is very basic.
    What I’m trying to do is take matchmove data generated in Syntheyes and apply it to a camera in an existing C4D project, render that out and composite it behind the original greenscreen footage.
    The tracking all looks great in Syntheyes and matches well in AE but when I bring it in to C4D (via Lightwave scene) it’s as if the scale of the camera movement is way too small. What am i missing?
    Thanks.
    Samuel Hall
    DP/Editor/VFX/Music
    http://www.vimeo.com/samhall
    Duca Simone luchini replied 8 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Adam Trachtenberg
    July 29, 2013 at 8:18 pm
    I’ve never had a problem with Syntheyes LW export into Cinema. When you bring in the camera and then load the movie into a texture, and place the texture on a Background Object, it doesn’t match up? Is that what you’re saying? I don’t know what you mean when you say you’re applying it to a camera in an existing scene. The point of the LW import is to bring in the animated camera from Syntheyes. Then you can use the Syntheyes markers to establish the proper scale for your Cinema Scene/objects.
  • Samuel Hall
    July 29, 2013 at 9:18 pm
    Sorry I’m probably not explaining things well because I’m so out of my element here. The situation is that I have a virtual set that’s already been set up for me to composite the talent into. What I need to do is get the camera data into that C4D scene so I can render the background and do the comp. The problem is that when I do that (either via Lightwave scene, C4D python script, or AE) it’s as if the camera and it’s motion path are tiny compared to the rest of the scene.
    Samuel Hall
    DP/Editor/VFX/Music
  • Adam Trachtenberg
    July 29, 2013 at 9:33 pm
    Okay, I was confused because I always start out with the tracked scene and then set up the 3D scene to match. In your case it’s going to take some extra work. First, when you import your LW scene you should get a dialogue asking what scale you would like to use. I think default is 10. You might try setting that to 1000, or even 10,000 instead, to get closer to the mark.
    I would also create some objects in Syntheyes that you can use as landmarks inside of C4D. For example, you might create a small box and place it at the corner of a desk. Then what you might do is put your 3D models in a null that’s centered at that box. That would give you a reasonably close point from which you could scale your 3D scene to try and match the BG footage.
  • Brian Morse
    July 30, 2013 at 12:41 pm
    Another option may be to export your scene from C4D as an obj and bring it in to syntheyes. Then you can scale your scene in syntheyes to fit. If your scene in C4D is large you could just export out certain objects.
  • Samuel Hall
    July 31, 2013 at 2:39 pm
    That’s really helpful. I actually ended up bringing all the geometry from the virtual set project into my matchmove project and scaled the world to fit. Works wonderfully now.
    Samuel Hall
    DP/Editor/VFX/Music
  • Samuel Hall
    That’s an interesting idea. I’ll have to try that. Thanks.
    Samuel Hall
    DP/Editor/VFX/Music
  • Duca Simone luchini
    July 11, 2018 at 8:52 am
    Hi Brian,
    can you explain how can you scale the Syntheyes scene after importing real scene size from C4D’
    I made the same process and I found that the 3d reference object imported is very large and don’t match the Syntheyes scene. Now I should resize Syntheyes scene but I don’t know how to make it.
    I try to set up World Scale but it reduce only the scene visualizzation and the imported mesh remains too big.
    Please Help!
