Activity Forums Blackmagic Design SynthEyes and Decklink
  • SynthEyes and Decklink
    Posted by Max Hagelstam on May 17, 2005 at 9:45 am
    Hi all!
    Is anyone else using the SynthEyes tracker software together with a Decklink-card (https://www.ssontech.com/)? For some weird reason, the Decklink installer mess up the SynthEye DV Clip reading ability. In other words: SynthEyes can read DV clips BEFORE you install the Decklink driver. After installing the 4.8.1 driver all DV Clips are black/multicolored garbage. If I uninstall the Decklink driver, all is well. Is there a solution for this?
    /Max
    Max Hagelstam replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
