Activity Forums Adobe After Effects Syntheyes, AE and Greenscreen Problem
  • Syntheyes, AE and Greenscreen Problem
    Posted by Eric Goldstein on May 16, 2008 at 4:54 pm
    I’m working on a fairly complex AE project and I’m using or attempting to use Syntheyes to track (3D)a scene shot against greenscreen. I used chromakey blue tracking marks on the green so that I could key them out.
    Syntheyes seems to be having problems with the greenscreen setup. Does anyone have any syntheyes/greenscreen experience? If so, I’d like to get more specific about the problems I’m having.
    Thanks for any help,
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 18 years, 4 months ago 2 Members · 2 Replies
  • Joey Foreman
    May 16, 2008 at 7:55 pm
    Are you manually setting track point or automatically? If you’re trying to do it automatically then Syntheyes is tracking points on your actor as well as the marks on the greenscreen. This will screw up the track.
    The actor must be masked out either before bringing the shot in, or within Syntheyes.
    You didn’t really give any details as to what’s going wrong, so this was just a guess.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Eric Goldstein
    May 16, 2008 at 10:54 pm
    Hi Joey,
    Thank for responding. I’ve tried tracking both automatically and manually. When tracking automatically, I’ve used the greenscreen mode, which allows you to use a key from the greenscreen to mask out foreground such as actors. I’ve also tried preprocessing the footage both in Syntheyes and separately in AE to make the footage hi contrast, black and white, turn the tracking marks red and various combinations of those things to get a better track. But, Syntheyes seems to have trouble with greenscreen regardless.
    Eric
    Eric Goldstein
    Los Angeles
