Activity Forums Adobe After Effects Expressions Syntax for returning value that alternates 0,1,0,1,0,1?
  • Syntax for returning value that alternates 0,1,0,1,0,1?
    Posted by Marc Brown on May 24, 2008 at 7:36 pm
    I have a project in which I must find a way of returning an alternating value (like 0,1,0,1) based on the frame number (ie, Frame 0: zero. Frame 1: one. Frame 2: zero. Frame 3: one. Etc.) I thought I had solved the problem through the use of relevant posts in this forum. At first, I was trying this:
    positionEven = 239;
    positionOdd = 240;
    f = thisComp.frameDuration;
    if (f%2 == 0) [360,positionEven] else [360,positionOdd]
    Unfortunately, a further problem is that I am forced to make use of AE6 because a plugin I wish to use will only work in AE6 (it breaks interestingly in AE7). Sadly, AE6 does not appear to possess syntax which covers “thisComp.frameDuration”. So I instead made a slider and based the formula off that:
    positionEven = 239;
    positionOdd = 240;
    f = thisComp.layer(“blargh”).effect(“Slider Control”)(“Slider”);
    Now, the real trouble here is that I am not sure what f%2 is supposed to return. My assumption was that it was a sort of shortcut which essentially spat out the even/odd status of whatever number “f” is. An inspection of the results would seem to confirm this as first. But as I sadly discovered after a six hour render, the formula stops working reliably after a few seconds’ worth of frames. Suddenly, instead of a consistent 0,1,0,1,0,1 we start getting a lot of 0,1,1,1,0,1,0,1,1,1. So whatever f%2 does (and believe me: it’s tough to Google “%2” and find out), it’s not what I thought.
    So that’s where I’m at. I still very much need a way of returning a solid 0,1,0,1 from start to finish, and the %2 function is not the solution. Please help. ;p I was hoping to have it all wrapped up by today and this fun problem is killing me.
    Marc Brown replied 18 years, 4 months ago 2 Members · 2 Replies
  • Dan Ebberts
    May 24, 2008 at 8:37 pm
    Try this (I don’t have time to test it right now, but it should be close):
    positionEven = 239;
    positionOdd = 240;
    f = Math.round(time/thisComp.frameDuration);
    Dan
  • Marc Brown
    May 25, 2008 at 11:57 am
    I don’t know how it works, but it works. Thanks! It’s a sure bet that without your help, I’d have spent the whole day puzzling it out rather than starting a fresh render.
    I’ll worry about the ins and outs of that formula when I have more time. ;p
