  • Posted by Hamid Noshadi on December 15, 2015 at 8:45 pm
    hi i’m new in after effect and an i have a problem .
    tnx to helping me.
    how can i fix this?
    //Data from THIS LAYER > Position > "X" Only
    center_X_con = 7.2 ;
    center_X_var = pickwhip ;
    left_X_con = -242/8 ;
    //Data from THIS LAYER > scale
    scale_X_center = 100 ;
    scale_X_var = pickwhip ;
    scale_X_side = 37/3 ;
    //THAT'S IT! I'll take it from here
    dist_pos=left_X_con-center_X_con;
    dist_scale=-(scale_X_center-scale_X_side) ;
    center modif=math.abs(center_X_var-center_X_con);
    x=scale_X_center+((-center_modif'dist_scale)/dist_pos) + (scale_X_var-scale_X_side) ;
    [x,transform.scale[1]]
    Melisa Bala replied 8 years, 6 months ago 3 Members · 2 Replies
  • Kalleheikki Kannisto
    December 16, 2015 at 8:45 am
    it seems that
    should be
    center_modif*dist_scale
  • Melisa Bala
    February 14, 2018 at 6:36 pm
    You should delete the spaces before “;” And try turning X’s into lowercase, and “m” from Math to the uppercase.
    dist_pos=left_x_con-center_x_con;
    dist_scale=-(scale_x_center-scale_x_side);
    center_modif=Math.abs(center_x_var-center_x_con);
    x=scale_x_center+((-center_modif*dist_scale)/dist_pos) + (scale_x_var-scale_x_side);
