Activity Forums Apple Final Cut Pro Legacy Syncronization between ep and sp clips
  • Syncronization between ep and sp clips
    Posted by Jason Griffith on December 22, 2006 at 5:05 am
    Hello,
    2 years ago I had some friends shoot my wedding. However since they were new to video and not on the same page… One camera was set to EP and the other was on SP. They had tried to edit it with Vegas with very little luck and alot of tedious work. Now that I just got the raw footage, I would like to see what I could do to salvage it. Does anyone know if there is anything that I should be aware of that would help me to make sure these clips will be in sync when I place them into the timeline? Whether or not there are certain settings or if there is a specific work around that would help solve the problem? Or even to know that there is no known fix would be helpful as well.
    Jason
    “An Unexamined Life Is Not Worth Living” – Socrates
    Jason Griffith replied 19 years, 8 months ago 4 Members · 4 Replies
  • Bret Williams
    December 22, 2006 at 7:47 am
    Dub the EP tape to a SP tape?
  • Bouncing Account needs new email address
    December 22, 2006 at 11:38 am
    First, I must assume you’re talking about “DV” format.
    There is no inherent quality difference between SP and LP (you say “EP”).
    They both run at the same frame-rate and the audio is identical.
    The only difference is “physical” in that the tape is pulled past the heads at a 1/3-slower rate in LP than in SP.
    So, once you capture the two tapes, they will edit together perfectly.
    But THAT’s the real problem… LP tapes tend to NOT play on any device other than the exact camcorder they were recorded on. That’s because the track-spacing at the slower speed is so CLOSE that if there is any imperfection in the head-alignment between two units, the LP tape will likely mistrack and the video/audio will get blocky and drop-out.
    So…
    If (IF) you can get the LP tape to PLAY into FCP… you simply edit as normal… there should be no sync problems at all.
    I can’t speak to the specific problems of the other edit system (it would be no different as far as sync on that system) but I also can’t speak to others’ editing skills, either.
  • Chris Poisson
    December 22, 2006 at 6:13 pm
    Matte may be right, but I have some old (wedding!) tapes shot the same way, I do what Bret says and just dub them via FireWire to another DV tape. Works great, since my DSR 11 won’t play EP tapes.
  • Jason Griffith
    December 23, 2006 at 2:56 am
    Thanks Guys,
    I had thought about dubbing to an sp format but wasn’t sure if that would be a fix before I attempted. Now that I know that someone has done it with success, I will proceed in that direction. Thanks so much for the input.
    Jason
