Activity › Forums › Apple Final Cut Pro Legacy › Syncing video tracks
  • Syncing video tracks
    Posted by Kevin on December 28, 2005 at 1:54 am
    Hi list,
    Wondering if there’s anyway I can have two video clips track each other in side-by-side viewers i.e once two tracks are synched up, is it possible to “gang” them so when you move through track B in viewer A the playhead moves to the exact same spot in track B. I know I can do this in with a multitrack but I’m curious if there’s a quick way to achieve the above in two viewers.
    Many thanks and warm regards,
    kevin
    Arnie Schlissel replied 20 years, 9 months ago 3 Members · 2 Replies
  • Thaxter Clavemarlton
    December 28, 2005 at 3:21 am
    One in the Canvas and one in the Viewer will work.
    You can gang them together.
    You can also just edit each one to a separate video track on the same timeline.
  • Arnie Schlissel
    December 28, 2005 at 3:59 pm
    If you’re using FCP 5, you can use the multiclip feature to do this. It’s covered in the manual.
    Arnie
    https://www.arniepix.com
