Activity Forums Adobe After Effects Expressions Syncing text to audio
  • Syncing text to audio
    Posted by Henri Yates on January 10, 2020 at 2:52 pm
    Hi.. I wanted to sync my voice-over with markers aligned perfectly to each word said in the VO. I want to sync the VO with its corresponding text to the text appears as the word is being spoken… I tried using expressions but it doesn’t sync perfectly. Is there a mistake in my expression or my expression is completely wrong.
    Here’s my code
    Cheers.
    // TypeMonkey
    m = thisComp.layer("1.mp3").marker;
    rate = 20;
    n = text.sourceText.length;
    d = n/rate;
    pre = d/2;
    t = time
    n = 0;
    if (marker.numKeys > 0){
    n = marker.nearestKey(time).index;
    if (marker.key(n).time > time){
    n--;
    if (n == 0){
    0
    }else{
    m = marker.key(n);
    myComment = m.comment;
    t = time - m.time;
    try{
    actMarker = action.marker.key(myComment);
    if (action.marker.numKeys > actMarker.index){
    tMax = action.marker.key(actMarker.index + 1).time - actMarker.time;
    }else{
    tMax = action.outPoint - actMarker.time;
    t = Math.min(t, tMax);
    actMarker.time + t;
    }catch (err){
    0
    linear(t,0,d,0,100)
    Dan Ebberts replied 6 years, 6 months ago 2 Members · 7 Replies
  • 7 Replies
  • Dan Ebberts
    January 10, 2020 at 8:02 pm
    It looks like maybe you took several unrelated expressions and mooshed them together somehow. In any case, this should give you one basic way to sync the text to the markers:
    n = 0;
    if (m.numKeys > 0){
    n = m.nearestKey(time).index;
    if (m.key(n).time > time){
    n--;
    if (n == 0){
    }else{
    m.key(n).comment;
    Dan
  • Henri Yates
    January 10, 2020 at 9:56 pm
    Thanks for replying sir.
    I tried your solution. Unfortunately, it didn’t work. It gave me this error;
    After Effect warning: an expression was disabled as a result of an error.
    Error at line 0 in property ‘Start’ of layer 5 (‘layer name’) in comp ‘5’.
    invalid numeric result (divide by zero?).
    What do you suggest I should do?
    Thanks again.
    Cheers
  • Dan Ebberts
    January 10, 2020 at 10:54 pm
    Sorry, I don’t notice you had the expression applied to a range selector. I assumed the text was coming from the markers, so that expression is for the Source Text property.
    Dan
  • Dan Ebberts
    January 14, 2020 at 12:25 am
    Henri,
    I got your emails, but my replies get returned immediately with a permanent error rejection message. I’m not sure why, but I’ll post here instead.
    What you’re describing is a lot trickier, because the expression has to be able to figure out how many characters were used in all the words triggered by previous markers. Not impossible, but considerably more complicated. I don’t have the time to do it right now, but maybe someone can crank it out for you.
    Dan
  • Henri Yates
    January 14, 2020 at 8:44 am
    Oh bummer, but thank you sir. I appreciate your help so much.
    Cheers.
  • Dan Ebberts
    February 6, 2020 at 8:01 pm
    For your latest question, you could use an opacity expression like this for the text:
    fade = .25;
    m = thisComp.layer(“1.mp3”).marker;
    n = 0;
    if (m.numKeys > 0){
    if (n == 0){
    0;
    }else if (n == 1){
    t = time – m.key(n).time;
    ease(t,0,fade,0,100);
    }else{
    if (time < m.key(n).time){
    t = m.key(n).time – time;
    }else{
    Dan
  • Dan Ebberts
    February 7, 2020 at 7:55 pm
    OK, I didn’t understand what you’re doing. Try this. Add an Opacity Animator and set the Opacity value to 100. Add an Expression Selector and delete the Range Selector. Set the Expression Selector “Based On” parameter to Words, and replace the Amount expression with this:
    fade = .25;
    m = thisComp.layer("R.Smalls.mp4").marker;
    n = 0;
    if (m.numKeys > 0){
    if (time < m.key(n).time) n--;
    if (textIndex < n){
    0;
    }else if (textIndex == n){
    t = time - m.key(n).time;
    ease(t,0,fade,100,0);
    }else{
    100;
    Dan
