Activity › Forums › Adobe Premiere Pro › Syncing Problem
  • Syncing Problem
    Posted by Lolosponja on December 17, 2006 at 9:57 pm
    I’m trying to get a clip to play at the command of a bass drum. Its pretty close but its off. My problem is that even when viewing the time line as close as possible the beat is in between 00;00:21;20 and 00;00:21;21
    Vince Becquiot replied 19 years, 9 months ago 2 Members · 4 Replies
  • Vince Becquiot
    December 18, 2006 at 12:03 am
    You can get much more accurate reading if you switch your timeline to Audio Units (arrow in top right of the timeline)
    Zoom the timeline all the way in and you will then be advancing sample by sample instead of frame by frame.
    Vince
  • Vince Becquiot
    December 18, 2006 at 12:12 am
    BTW, you may also want to do that in the source monitor before putting the audio in the timeline. You will be getting a much bigger waveform, just hit * and create a marker, then match it in the timeline afterwards.
    Vnce
  • Lolosponja
    December 19, 2006 at 9:31 am
    Thankyou for the tip, but i still get get my video to start where i want it its still only goes frame by frame = (
  • Vince Becquiot
    December 19, 2006 at 6:20 pm
    Do you mean that the audio is going frame by frame ? The video of course will only refresh every frame, but you should be able to get sample accuracy on the audio which is really what you are syncing to..
    Vince
