Activity Forums Maxon Cinema 4D Syncing Noise Displacement with audio
  • Syncing Noise Displacement with audio
    Posted by Ryan Ainge on October 7, 2010 at 2:54 pm
    I’ve been looking all over the internet for a tut on this and still nothing.
    Wanting to sync my soundfx to the noise displacement on my object. Would I use sound effector? If so, how?
    Here is an example:
    https://vimeo.com/10339591
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Dominic Plaza replied 11 years, 7 months ago 5 Members · 5 Replies
  • Adam Trachtenberg
    October 7, 2010 at 11:22 pm
    Yes, you can use the sound effector. You’d have to do it with xpresso. Basically you would connect the sound effector to a mograph sample effector node. The sample effector’s strength output would be connected to a rangemapper in port, and the range mapper’s out port would be connected to the material’s displacement height port. Then you’d have to adjust the range mapper’s output height to get the desired effect.
  • Ryan Ainge
    October 8, 2010 at 3:30 am
    Thanks Adam. I haven’t used xpresso yet, so this will be a good time to test it.
  • Cory Petkovsek
    October 8, 2010 at 4:27 am
    That is so sick. I love it. Makes me want to play in 3D all day!
    Cory Petkovsek
    Corporate Video
    http://www.CorporateVideoSD.com
  • Scyld
    December 21, 2010 at 8:33 pm
    adam
    is there any chance you could do one of your super clear video tutorials of this technique (like you did for me with transitioning between textures) if you get the time?
    you’d make me a very happy chappy. you are the C4d guru…
    happy holidays to you!
  • Dominic Plaza
    January 29, 2015 at 3:33 pm
    https://www.youtube.com/watch?v=o60mCtDxvt4
