Activity › Forums › Apple Final Cut Pro › Syncing multiple frame rates, multiple audio frequencies
  • Syncing multiple frame rates, multiple audio frequencies
    Posted by Jason Rushton on May 31, 2012 at 4:01 am
    Dear friends,
    [This post may better belong in another thread, however, since I am using fcpx I have put it here].
    I’ve been asked to edit some videos of lectures.
    The lectures, I have just realised, were filmed on two different cameras with two different frame rates (29.97fps and 30fps) and two different audio frequencies (48khz and 44.1khz).
    I don’t know if this matters or not, but the codecs are different too: Camera 1 uses Linear PCM, XDCAM EX 1080i60 (35 Mb/s VBR), Camera 2: AAC, MPEG-4 Video.
    At the moment, the clips are going hideously out of sync very quickly in fcpx. Is there a way to make them line up nicely?
    Thank you very much for your help. Best regards,
    Jason.
    Jason Rushton replied 14 years, 4 months ago 1 Member · 1 Reply
  • Jason Rushton
    June 2, 2012 at 6:28 am
    I’m really stuck with this one, even where to begin… Any pointers any of you could provide would be most appreciated.
    Thank you.
    Jason.
