Activity Forums VEGAS Pro Syncing issues with video and audio
  • Syncing issues with video and audio
    Posted by Kayley Grace on September 22, 2011 at 1:05 am
    Hi there,
    I have a 1 hr video that has syncing issues. The audio constantly goes in and out of sync.
    I have tried to sync is in sony vegas but don’t seem to be able to do it. I’m using sony movie vegas HD.
    I’m guessing I will have to crop the audio each time is goes out of sync, but how do i get it to line up perfectly. When I move the audio it jumps in frames, how do I get the audio to move slightly to the left or right?
    Many thanks in advance for your help.
    Kayley.
    Kayley Grace replied 15 years ago 3 Members · 6 Replies
  • Dave Lozinski
    September 22, 2011 at 2:06 am
    Do you have “snapping” enabled? If so, disable it and it will allow you to move clips a little bit at a time in the timeline.
    That should allow you to line up things perfectly. Make sure to zoom in to the timeline if you have to.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
  • Mike Kujbida
    September 22, 2011 at 2:10 am
    [Kayley Grace] “I have a 1 hr video that has syncing issues. The audio constantly goes in and out of sync.”
    Where did the video come from (camcorder or somewhere else)?
    Is the audio a totally separate from the video?
    What format is the video (miniDV, HDV, AVCHD)?
    What are your computer specs?
  • Kayley Grace
    September 22, 2011 at 4:17 am
    Thanks Dave, I have found the snapping and have disabled it. Now it seems that I can’t hear the 2nd audio track I have.
    What I have is a 1 hr video that is out of sync and I have this side and the other side audio tracks that I am trying to line up with the video. I can hear the other side audio but can’t hear my side audio.
    I inserted a new audio track and put it there. Have I missed something?
  • Kayley Grace
    September 22, 2011 at 4:28 am
    Mike ok here is what I’ve done.
    Using skype I recorded a 1 hr video using vodburner as the recorder.
    I have the two sides of the audio as separate files.
    The video is a WMV file.
    My pc specs: I have windows 7 64 bit- emachine 640G laptop. upgraded to 6g ram, dual processor.
    That’s all I know about the specs I can probably find out more if you need more info than that.
    Thanks Kayley
  • Kayley Grace
    September 23, 2011 at 4:30 am
    Found all the specs which I have put below.
    AMD Athlon II P340 Dual Core Processor (its not a quad core) 2.20Ghz (Gigahertz)
    6GB DDR3 RAM with 1066 FSB (Front Side Bus = easy explanation – speed limit of data flow)
    64 Bit Operating System
    Windows 7 Home Premium SP1
    ATI Mobility Radeon HD5470 Video Card with 512MB Dedicated DDR3 RAM
    Realtek HD Audio
    Hitachi 500GB HDD
  • Kayley Grace
    September 23, 2011 at 4:32 am
    Also can you let me know how to zoom in on the timeline. the audio is a fraction out and I can get it just before and just after but not spot on, in the place I need it to be. Is there another way to move the audio other than a mousepad. Can I use arrows?
    Thanks Kayley
