Activity Forums Apple Final Cut Pro Legacy Syncing Hell?
  • Posted by Todd Gillespie on August 5, 2005 at 12:13 am
    Hi All,
    I’ve done enough syncing with FCP in my day, but this is the Uber sync. I’m about to start syncing a program and I’m wondering the best way to do it.
    Scenario: 3 iso camera tapes plus a Master switched. I did the assemble edit with a paper edit of all 4 tapes, so I didn’t set up a multi camera sequence/edit. Now I need to sync all the camera cuts with the Master audio. Problem is that it’s not contiuous. So everytime I cut to another tape, I need to sync to the Master Switch tape.
    So…with 80ish cuts, that’s a lot of syncing!!!
    I need something like the Master Tape on a Multi Edit that I can drop every shot into slide it around until it’s synced, then drop it back down?
    But not sure that would even work???
    Todd at UCSB
    Television Production
    Todd Gillespie replied 21 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
