Activity › Forums › Apple Final Cut Pro Legacy › Syncing FCP 4.5 render with DVD Studio Pro
  • Syncing FCP 4.5 render with DVD Studio Pro
    Posted by Paxwarrior86 on September 22, 2005 at 4:01 pm
    I tried to changing the encoding properties in DVD Studio Pro. Now it takes forever to encode the files, whereas before I believe it left the same encoding as FCP and just had to mux them. Does anyone know what the original setting are for the encoder on DVD Studio Pro or perhaps how I can tell what bit rate FCP encodes at so I can set DVD Studio to that?
    Jerry Hofmann replied 21 years ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 23, 2005 at 1:37 pm
    Trash your preference file for DVD SP, and it will go back to the default settings. I get really nice results encoding with DVD SP 4 with a CBR setting of 7… but the files are large enough that the most you can put on a 4.7 disk is about 60 minutes.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
