Activity Forums Adobe After Effects Syncing conversation between same person
  • Syncing conversation between same person
    Posted by Chilllax on February 18, 2007 at 11:07 pm
    I am having trouble syncing a conversation between myself. I am using a green screen and have no problems keying out the background and the masks are not an issue either. I just can not figure out a way to sync the conversation.
    If anyone could provide me with a few pointers or tips, I would really appreciate it. This is for my lit class, and I wanna make sure its excellent 🙂
    Chilllax replied 19 years, 6 months ago 2 Members · 2 Replies
  • Dan Blaim
    February 19, 2007 at 3:44 am
    Sometimes when you do a RAM preview the audio will not sync with the video, especially if you have effects applied to your layers. You could render a portion of the video and view it in realtime. However if you are playing back your ram preview and your info palet states that it is playing realtime, you may need to tweak the placement of the clip. Try selecting your clip (with the audio) and press LL. This should bring up your audio waveform for that layer. Use it to “see” your audio and slide the clip until your audio syncs.
    Good Luck
  • Chilllax
    February 19, 2007 at 4:38 pm
    Thanks for the response, but for some reason the video of myself that actually has audio even after rendering it doesnt move fluidly and there isn’t any audio. But when I play the clip outside of after effects everything is fine, my movements are fluid and there is audio.
