Activity Forums Adobe After Effects Expressions syncing Camera’s position Keyframes with Layer startTimes
  • syncing Camera’s position Keyframes with Layer startTimes
    Posted by Aled Rhys jones on October 30, 2006 at 6:33 pm
    I have a comp that has 4 nested comps (set to 3D) and a Camera.
    The 4 nested comps come in at different times in the timeline.
    They are arranged side to side (next to each other on the X axis like posters on a wall).
    The Camera moves from one comp to the next accross in the X axis, pauses, then shifts to the next comp. This move is set to take varying amounts of time from one ‘poster’ to the next. (all-in-all there are 8 keyframes).
    I would like to set up the comp so that the editor can ‘slip’ any of the comps in the timeline without having to worry about moving the keyframes of the camera.
    i.e.:
    Whatever the startTime of nested Comp 1, Keyframe (1) is synced with it.
    Keyframe (2) is always 0.92 seconds after Keyframe (1).
    Whatever the startTime of nested Comp 2 is, Keyframe (3) is synced with it.
    Keyframe (4) is always 1.24 sec after Keyframe (3).
    …and so on.
    I hope I’ve made sense and that someone out there can help.
    Kind Regards
    Al
    Filip Vandueren replied 19 years, 10 months ago 2 Members · 1 Reply
  • Filip Vandueren
    October 31, 2006 at 2:51 am
    This works:
    l=[];
    // the 4 nested compLayers
    l[0]=thisComp.layer("Comp 1");
    l[1]=thisComp.layer("Comp 2");
    l[2]=thisComp.layer("Comp 3");
    l[3]=thisComp.layer("Comp 4");
    d=[];
    // the 4 delaytimes:
    d[0]=0.92;
    d[1]=1.24;
    d[2]=0.2;
    d[3]=0.2;
    value;
    for (i=0; i<4; i++) {
    if (l[i].inPoint<time) {
    linear (time, l[i].inPoint, l[i].inPoint + d[i] , key(i*2+1).value, key((i+1)*2).value);
    if ((i<l.length-1) && (l[i].inPoint + d[i] <time)) {
    linear (time, l[i].inPoint + d[i], l[i+1].inPoint, key((i+1)*2).value, key(i*2+3).value);
    NB:
    – you can change the two occurences of linear to ease, easeIn or easeOut if you prefer that.
    – IMPORTANT: if you see “& lt ;” in the first line instead of a “lesser than” sign in the first line of the script, go to the webiste and copy the expression from there !
    The thing about these kinds of solutions is, that if your editor is after-effects-agnostic enough to not be able to move 2 keyframes, he sure as hell won’t know what to do when a bunch of javascript errors pop up after he accidentally removes a layer. Undo will restore the layer, but not the expression…
    So this is more of a ‘proof-of-concept’ expression than a recommendation for a workflow if you catch me 😉
