Activity Forums Apple Final Cut Pro Legacy Syncing Audio with different Tempos
  • Syncing Audio with different Tempos
    Posted by Lorenzo Escalante on September 27, 2010 at 8:03 am
    So I have a problem.
    I am editing a live performance for a band and they want to use audio that they have just recently recorded…..only problem is….its a 15 minute mix of a number of michael jackson songs….and the live version has a different tempo with the recorded version…..
    is there any way to sync the recorded audio with the live audio and have the tempo switched automatically??? or is it something that i have to manually…=(..
    PLEASE CREATIVE COW COMMUNITY. HELP ME!
    Michael Gissing replied 15 years, 12 months ago 4 Members · 3 Replies
  • Shane Ross
    September 27, 2010 at 8:43 am
    Man, there is no way. Not unless they listened to the playback WHILE they were performing, to match what they recorded in studio. Because yeah, the performances are very different.
    Well, there isn’t NO way. You will have to do a lot of editing, cut aways. Find chunks here and there that match up, and piece things together. A lot of work…
    Shane
  • Nick Meyers
    September 27, 2010 at 12:36 pm
    i’ve had to do this a fair bit.
    generally it’s because i’ve got multiple live takes, and best audio is from one, and best picture is from another.
    generally i’m just dipping into the non-sync take. a whole song would be harder,
    but here is my approach:
    do an edit on the take you want to use.
    do the best edit you can on it.
    then
    take that edit,
    and lay it up in a new sequence against the audio you need to use.
    lock the OK audio tracks and just go though the whole edit pulling it into sync.
    don’t be fussy about this.
    as soon as it’s a frame out of sync (or sooner really) trim a frame.
    doesn’t matter if it’s in the middle of a shot,
    or if you have 3 or 4 trims in the middle of a shot.
    once you are done with this process, copy the sequence.
    now go though the copy and start cleaning up the edits
    using either the roll tool or the extend function.
    the trick is that you can get away with slightly loose sync at the start of most shots as long as they then come into sync.
    one freaky thing i found was that on some shots i could add or remove frames invisibly.
    depends on how much movement there is of course.
    i had a close up of a singer once and needed to remove some frames.
    i found that if i did it on their natural “holds” it would work
    in the line “cos i-i-i-i-i will always love you-o-o-o-o” the holds would be pretty much where the dashes are
    of course if your two sources are WAY out of sync then you can start looking for cutaways etc.
    how out of sync are they?
    i had to do a clip once where it needed a frame removed every second.
    no tricks worked there.
    it just looked stepy.
    a strobe filter will make that look intentional!
    nick
  • Michael Gissing
    September 27, 2010 at 9:53 pm
    I couldn’t get past the fact that they are Michael Jackson songs and the cost of licensing the music will be the main problem.
    When this sort of sync is a problem, you have to cut around the issue as as has been said and/ or speed up/ slow down the live video to better match the tempo of the recorded music.
