Syncing Audio for Multicam editing
Posted by Don Cobble on November 10, 2011 at 6:16 pmI have the audio tracks lined up (almost). I have one track that is at the beginning of a frame and the other is at the end of the same frame. Is there any way to nudge the tracks to match? when I move they jump a whole frame + or -? is it possible or am I expecting to much?
Thank U for HelpPC
I7 2.8 Ghz 8GB Ram
Win 7 Pro 64bit OS
PNY Quadro 40003-4 TB HD
Vegas 10 64bit & Vegas 11 64Bit & Adobe Production Premium CS5.5Camera
Sony EX1 shoot in 1920×1080 30PBrad White replied 14 years, 10 months ago 5 Members · 9 Replies -
Ted Snow
November 10, 2011 at 6:36 pmIn the Menu under Options…uncheck Quantize to Frames.
ASUS P8P67 Deluxe MB
EVGA GeForce GTX 560 Ti 1 GB DDR 5
Intel i7 2600k 3.4 Ghz
Corsair HX750 power supply
Two Seagate Barracuda 500g SATA III drives
16 Gig G.Skill Ripjaws DDR3 1600
Canopus ACEDVio card
Thermaltake V9 BlacX Edition case
Xigmatek Dark Knight CPU Cooler
Win 7 Pro
VEGAS 8.0
VEGAS 11.0 32 & 64 bit
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Don Cobble
November 10, 2011 at 6:53 pmI am in Vegas 11 and do not find that in the preferences? Is it somewhere else in 11? or do I need to look again maybe somewhere else?
thank UPC
I7 2.8 Ghz 8GB Ram
Win 7 Pro 64bit OS
Sony EX1 shoot in 1920×1080 30P -
Ted Snow
November 10, 2011 at 7:17 pmNot in the preferences…in the MENU…across the top of the page. File, Edit, View, Insert, Tools, OPTIONS, Help. Click on OPTIONS, “Quantize to Frames” is the first option at the top.
Win 7 Pro
VEGAS 8.0
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Don Cobble
November 10, 2011 at 7:22 pmThank U
PC
I7 2.8 Ghz 8GB Ram
Win 7 Pro 64bit OS
Ted Snow
November 10, 2011 at 7:52 pmYou’re welcome. You might want to turn “Quantize to Frames” back on once you are finished tweaking.
Win 7 Pro
VEGAS 8.0
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Mike Kujbida
November 10, 2011 at 8:02 pmMake that definitely turn “Quantize to Frames” back on once you’re finished tweaking or you leave yourself open to all kinds of grief.
Here’s one guy’s recent post about neglecting to make sure it was enabled.Having that Off by mistake caused me much grief. Really bad outcomes with mixed progressive and interlaced footage. The “P” ended up a juddery mess, half my cuts blinked and even the interlaced footage in parts was a bit juddery.
Not so obvious on the LCD monitors while editing but once burned to DVD and played back on a CRT TV, yuck. -
Ted Snow
November 10, 2011 at 8:16 pmThank you Mike…!
Win 7 Pro
VEGAS 8.0
Sony VX2100
Sony HVR-Z7U
Sony HDR-CX130
Alesis HD24 -
Brad White
November 13, 2011 at 11:58 pmI do a lot of multi camera editing and have found that using a “jog wheel” type controller is much easier and more accurate than using a mouse when trying to sync audio tracks. The jog wheel allows you to go back and forth one frame at a time while listening for the echo effect to disappear. The controller I bought is called a “ShuttlePRO v2” by Contour Design. It is USB, has 15 programmable buttons and a variable speed spring-return wheel for forward and reverse. There are templates include that allows the controller to be pre-set with various Vegas Pro versions. B&H and Amazon sell these for about $80.
Brad
