Activity Forums Adobe Premiere Pro Syncing a multicam with broken takes
  • Syncing a multicam with broken takes
    Posted by Luke Ogden on August 14, 2013 at 10:26 am
    I’ve got a two-angle interview shot on a fs700 and a 5D. naturally the 5D had to stop every 12 minutes so Ideally I’d like to get a multicam that can treat the broken up takes of the 5D as an angle with gaps. The default functionality in Premiere is making each of the takes as a new angle.
    I’ve managed this in the past in FCPX and have pluraleyes 3 which can sync it up but I’ve always had trouble with the XML that pluraleyes gives you and I don’t really want to start the projects in FCPX.
    Anyone know how to do this?
    27″ iMac 3.4 GHz Intel Core i7, 16GB 1333 MHz DDR3, OS X 10.7.5 //
    Roel Bus replied 13 years, 1 month ago 2 Members · 1 Reply
  • Roel Bus
    August 15, 2013 at 2:08 pm
    Luke,
    A workaround could be this: sync your long clip with the first 5D clip, open that multiclip in the timeline, and then lay the other clips over the first clip in that sequence. Unfortunately you have to manually sync those clips but once they are, the entire sequence acts as a multicam. The 5D track will have gaps, but it should then all be synced.
    The nice part about Premiere is you can modify multiclips after they are synced, add to them etc. it has worked for me with captured clips that had bad spots in them
