Activity Forums Apple Final Cut Pro Legacy Syncing 25 frames to 60 frames
  • Syncing 25 frames to 60 frames
    Posted by John Weber on June 26, 2014 at 7:46 pm
    I’m trying to sync up footage of the same action from two different sources. One is a skype interview recorded at 25 FPS, the other is a Canon vixia at 60 FPS. I’ve tried transcoding the footage to match each other, and it starts off fine but is always out of sync by the end. Need advice to fix this please, and reshooting is not an option at this point.
    Thank you.
    Mark Suszko replied 12 years, 2 months ago 2 Members · 2 Replies
  • John Weber
    June 26, 2014 at 8:26 pm
    The final video will be uploaded to YouTube at 30FPS. 60 would be ideal, but if 25fps is the only option I am more than willing to work with that.
  • Mark Suszko
    June 27, 2014 at 1:59 pm
    And of course, audio sample rates need to match or they will drift too.
