Activity Forums Adobe After Effects Synchronizing Video to Music
  • Synchronizing Video to Music
    Posted by Ut1l1ty on October 30, 2006 at 12:40 am
    This year for my film class I want to do a short that has images/video/text synchronized to music. I am planning to do a lot of the work in After Effects. However I have no idea where to start. Any ideas on the synchronization would be very helpful.
    Ut1l1ty
    Mike Clasby replied 19 years, 11 months ago 3 Members · 7 Replies
  • 7 Replies
  • Mylenium
    October 30, 2006 at 3:30 pm
    That pretty much depends on what you mean by “synchronized to music”. Is it a smooth, slick edit? Rhythmic fades/ transitions? Rhythmical blinking of any kind? Do you want to sync to the “mood” or to certain beats? Without knowing what footage and what sounds/ music, this could easily turn into an endless thread, so if you can provide some more info, it would be easier to provide some guidance.
    Mylenium
    [Pour Myl
  • Mike Clasby
    October 30, 2006 at 5:15 pm
    Here are two tuts from Adobe, the first one is step by step with AE’s “Convert Audio To Keyframes”:
    Using Music to Animate Text
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=396&xml=aft6audio
    Let Sound Drive the Motion
    https://studio.adobe.com/us/tips/tip.jsp?p=1&id=100172&xml=aft6ttsound
    The same principal is used with Trapcode
  • Mylenium
    October 30, 2006 at 6:42 pm
    Goodness, do you ever leave the computer, yikesmikes? Your posts are so elaborate and detailed, it’s kinda spooky. ;O)
    Mylenium
    [Pour Myl
  • Ut1l1ty
    October 30, 2006 at 9:35 pm
    Sorry for being a little vague. Here are some more details. The music track is going to be an trance/techno song and I do want video/images syncing with the beats. The way I think about it is how an equalizer will react to the music. Another example would be a text layer scaling up and down as the volume of the song gets louder and softer.
  • Mike Clasby
    October 31, 2006 at 1:26 am
    Here’s an equalizer:
    Creating an Animated Volume Meter by Talid Al Khatib
    https://forums.creativecow.net/cgi-bin/page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/al_khatib_talid/volume_meter/index.html
    And you might want to check out the AE Plugins Render> Audio Spectrum or Audio Waveform, they take their movement from an audio layer and will also climb onto a mask that’s on the layer (choice of mask under “Path”), apply these effects to solid layers or image layers.
  • Ut1l1ty
    October 31, 2006 at 1:31 am
    I have used the waveform plugin before, I did NOT know that you could apply it as a mask though. I’ll definitely try and do that equalizer as well. Thanks for the links.
  • Mike Clasby
    October 31, 2006 at 1:38 am
    Leave the computer? I don’t understand.
    It’s like marriage, ’til death do us part.
