Activity Forums Storage & Archiving Synchronizing is not happening on the DFS file
  • Synchronizing is not happening on the DFS file
    Posted by Edwards Willeam on November 4, 2009 at 1:19 am
    I have a list of shared files from the different file servers(DNF
    storage) on the network. i grouped them by using the DFS(distributed
    file system) on windows 2003 server. couple of folders i used to
    Synchronous (replicate to remote location). now Synchronizing is not
    happening.
    any help much appreciated.
    kind regards,
    Dufrence
    Irrani Dam replied 16 years, 10 months ago 2 Members · 1 Reply
  • Irrani Dam
    November 5, 2009 at 12:45 am
    1.The problem is that DFS-R is only supported in Windows Server 2003 R2 and later. For DFS-R, you can create a report for the replication –> MMC Snap- in for DFS-R and then it’s an action you can run on the replication-set. SBS 2003 does not support DFS-R not even SBS 2003 R2, which was, confusingly, not based on Win2k3 R2. The best way to synchronize the is to use Offline Files.
    2.Have a look at the network connections and make sure everything is up. Check router config if it has no disabled ports, that migh cause the problems… Do post back.
    Check it.
