Activity › Forums › Apple Final Cut Pro › Synchronized clips go from 1080p to 720p
  • Synchronized clips go from 1080p to 720p
    Posted by David Schmidt on September 7, 2011 at 11:56 pm
    This may have been discussed here before but I couldn’t find anything. I notice that when I synchronize clips the frame size changes from the original 1920×1080 that I shot to 1280×720. It also changes the frame rate from 29.97 to 23.98. I can change the entire project back to 1920×1080 in the properties menu but I can’t change the frame rate back to 29.97. This only happens with synchronized clips. The remaining clips don’t change.
    I am curious why it changes. It doesn’t seem to have any effect during playback but it doesn’t make sense.
    Brendan Gibbons replied 15 years ago 3 Members · 2 Replies
  • Jeremy Garchow
    September 8, 2011 at 12:09 am
    Yes, seems to be a bug.
  • Brendan Gibbons
    September 8, 2011 at 12:19 am
    Hi David,
    I remember this popping up a few weeks back.
    Have a read here, others have had the same issue.
    https://forums.creativecow.net/readpost/344/2998
    Seems synchronize function only works with 23.98
    A “slight oversight” on apple’s behalf!!!
    The way around it seems to be manually lining up your audio and video, make it into a compound clip and edit that into your timeline.
    Cheers,
    BG
