Activity › Forums › Audio › Synchronized 25 fps audio to 24 fps video footage
  • Synchronized 25 fps audio to 24 fps video footage
    Posted by Ori Burg on June 12, 2010 at 1:54 am
    I am now editing a movie that was shot on the canon 5D Mark II in 24 fps.
    The audio was recorded seperatly on frame rate of 25 fps.
    What is the best was to change the audio frame rate to 24 fps?
    Thank you,
    Ori
    Bouke Vahl replied 16 years, 3 months ago 2 Members · 1 Reply
  • Bouke Vahl
    June 13, 2010 at 7:56 am
    audio does not have a framerate, it has a sample rate defining the smallest element, but that’s unimportant.
    Both should run at the same speed.
    So no conversion needed whatsoever, it should sync as it is.
    Did you try this already? If so, and it did not work, what are your problems?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
