Activity › Forums › Apple Final Cut Pro › Synchronize Clips command failing in a simple situation: what am I doing wrong?
  • Synchronize Clips command failing in a simple situation: what am I doing wrong?
    Posted by Benjamin Reichman on February 23, 2012 at 1:03 am
    I have a 38-minute XDCAM EX clip (brought into FCP X via XDCAM Transfer) and a matching H4n audio clip. I selected both in FCP X’s Event Browser, and chose “Synchronize Clips” from the Clip menu.
    The result is a Compound Clip that plays both the camera audio and Zoom H4n audio–but out of sync by about two seconds.
    I know I can ‘step into’ the Compound Clip and manually sync the video and H4n audio, but what went wrong in the first place?
    The camera audio is at a low level, but it’s pretty clear, and I know PluralEyes wouldn’t have a problem with this. (And yes, I know I can run PluralEyes in FCP X).
    But I’m wondering, did I do something wrong or neglect some detail? I thought the synchronization in FCP X was supposed to be pretty solid. What’s happening?
    Noah Kadner replied 14 years, 7 months ago 2 Members · 1 Reply
  • Noah Kadner
    February 23, 2012 at 1:51 am
    Is it possible you have a project settings mismatch- i.e. 24 fps vs. 23.98 footage- etc. The Zoom is not SMTPE timecode accurate. For that long a take I wouldn’t be exactly floored by a bit of drift.
    Noah
    Call Box Training.
    Featuring the Panasonic GH2 and Panasonic AC160/130.
