Activity Forums Adobe After Effects Expressions synchronising two layers
  • synchronising two layers
    Posted by Kingsley Birkett on January 21, 2018 at 6:54 am
    I am really struggling to understand what I’m doing wrong, appreciate any assistance you can give.
    I have one layer that is a vertical strip with graduations and numbers 0-43000
    its dimensions are 88×22858 pixels
    I have another layer that is a rolling type odometer.
    I created a null layer which the vertical strip layer is moved vertically, ie in they Y axis.
    the number of the y position is then multiplied by a factor to cause the odometer to roll and match the vertical scale.
    unfortunately when I get to the the oppotite end of the scale it is a little out.. if I calibrate it at the centre, then its out a little at each end. any ideas ? thanks..
    Hammers Nail replied 8 years, 8 months ago 2 Members · 1 Reply
  • Hammers Nail
    January 22, 2018 at 12:51 am
    Hard to tell since we can only guess how much pixels in Y occupy those numbers, how offset those are, so measure yourself what is the actual distance between e.g. baseline of number 0 and number 43000. Then, have you taken in account that you have to take in account also the first/last number of scale? Assuming that it is really 22858.0px, then if Y-min is 0, then Y-max should be = (22858.0 – 22858.0/43001)
    Nh
