Activity Forums Adobe Premiere Pro Synching DV Video Clips
  • Synching DV Video Clips
    Posted by David Sapadin on May 3, 2008 at 7:44 pm
    Hi:
    I shot video with two mini-DV camcorders. While synching for multi-camera, I realized the two clips are off by 1/2 frame. In the timeline, Premier lets you move audio all the way down to “audio units” which would solve the problem except for that the linked video track won’t move less than a full frame. So if you synch the sound perfectly, then the video is off by 1/2 frame. Anybody know any way around this?
    David
    Harm Millaard replied 18 years, 3 months ago 3 Members · 3 Replies
  • Jon Barrie
    May 4, 2008 at 10:21 am
    If you unlink the video and the audio then you can move either of them witout it affecting the other. Meaning the audio can move 1/2 a frame which is about 24000 samples (half of 48Khz) the video won’t shift then if it’s not linked to the audio anymore.
    – Jon 🙂
    How many editors does it take to change a light bulb?
    http://www.jonbarrie.net
  • David Sapadin
    May 4, 2008 at 10:05 pm
    Hi:
    Yes thanks. I noted in my post I know I can move the audio. But then it is no longer in synch with the video. I am trying to figure out how, or if its even possible, to slide adjust) a video clip (which includes the audio track) less than one frame on the timeline, in one direction or the other. I am amazed at how I’ve managed to shoot the same event with 4 DV Camcorders and 2 are in perfect synch, the other other two don’t match the 1st two by 1/2 frame…but are in synch with each other!
    Dave
  • Harm Millaard
    May 5, 2008 at 8:59 am
    How did you establish that there is a discrepancy of a 1/2 frame? Video is recorded as 25 PAL or 29,97 NTSC frames. There is nothing in between. You can only move in whole frames.
    Harm Millaard
