Activity › Forums › Panasonic Cameras › Synching 2 VX-100s in free run
  • Synching 2 VX-100s in free run
    Posted by Kevin on January 27, 2006 at 8:46 am
    Hi list. I read the very helpful posts on this list about setting the free run with the same remote. Works a treat but my followup question is what happens when one or either camera is turned off. Does the freerun function keep cameras in sync or do you have to repeat this function each time.
    Many thanks in asvance for any insight.
    Peace,
    Kevin
    Noah Kadner replied 20 years, 8 months ago 3 Members · 4 Replies
  • Noah Kadner
    January 27, 2006 at 1:15 pm
    Free run is based on the internal battery’s clock so it will keep time in sync whether on or off.
    Noah
  • Kevin
    January 27, 2006 at 2:43 pm
    Awesome. Thanks Noah for posting back with this info.
    Peace,
    Kevin
  • Steve Wargo
    January 28, 2006 at 6:27 pm
    Even the most professional camera will lose sync after a while unless they are cabled together. We’ve run extensive tests with Sony DigiBeta and others and when you power down, there is a hesitation in the time code for some unknown reason. Unless we keep a cable running from an “outie” on one and an “innie” on the other, the time code will drift, even if both cameras are running in record the whole time. It shouldn’t happen but it does.
    Steve Wargo
    Tempe, Arizona
    It’s a dry heat!
  • Noah Kadner
    January 29, 2006 at 4:39 pm
    Within one day I’ve not had this happen on DVX’s but it’s definitely a possibility.
    Noah
