Activity Forums Apple Final Cut Pro Legacy Synched sound after log and capture
  • Synched sound after log and capture
    Posted by Lee Olivas on November 18, 2009 at 2:05 pm
    Can someone tell me other than adjusting the audio video settings why is footage is shot in 16 bit audio the audio would get unsyched when playing back in the viewer or when the footage is dropped in the sequence. I have had this happen whereas the students then have to manually move the audio and video around to match up.
    Sucks
    Ray Chung replied 16 years, 9 months ago 4 Members · 3 Replies
  • Jeremy Garchow
    November 18, 2009 at 2:54 pm
    Is this double system sound or audio that is on tape?
  • Chris Poisson
    November 18, 2009 at 4:08 pm
    You might try trashing prefs.
  • Ray Chung
    November 18, 2009 at 8:29 pm
    What is the format/frame rate of what you shot/loaded, and what is the ‘easy setup’ format/frame rate of FCP when you open it up?
