Activity Forums DaVinci Resolve Synced Audio Not Showing in Resolve 11 Timeline
  • Synced Audio Not Showing in Resolve 11 Timeline
    Posted by Jake Keller on August 19, 2014 at 9:44 pm
    Hi all,
    I read through the manual about syncing audio manually have followed the instructions exactly as written, however when I drop my clip onto the timeline it still retains the original camera audio. Does Resolve not sync off-camera audio to a clip that already has audio/video on it? This is probably an easy answer and a bonehead question, but thought I would ask 😛 Thanks!
    Jake
    Benjamin Steiner replied 10 years, 9 months ago 4 Members · 7 Replies
  • 7 Replies
  • Dmitry Kitsov
    August 20, 2014 at 2:18 am
    When you synch audio in the edit page either by hand or automatically the name of the audio clip is not updated in the Ui. The video clip retains exactly the same name of it audio portion without reflecting the change, but the audio is indeed replaced.
  • Glenn Sakatch
    August 23, 2014 at 6:07 pm
    Click on a clip in your timeline, call up your waveform view for the audio, and you should see the name of the audio file in the wave form window.
    Glenn
  • Dmitry Kitsov
    August 23, 2014 at 7:40 pm
    Glen,
    After audio is synced in the MEDIA (not merely linked in the EDIT), the name of the original audio clip – as it was before the sync – will NOT be visible in the EDIT, on the timeline.
  • Glenn Sakatch
    August 24, 2014 at 3:20 pm
    Correct, but if you click on the clip in the timeline, and call up your wave file view, that view will show you which audio clip you are listening to. You will see a different file name than what the timeline is showing.
    Glenn
  • Dmitry Kitsov
    August 24, 2014 at 10:50 pm
    What you describe is possible in the MEDIA tab, not in the EDIT tab.
  • Glenn Sakatch
    August 25, 2014 at 3:15 pm
    You are correct, the info only appears in the media tab. I guess my point is, if you are trying to confirm what audio is being used, that is where you do it.
    Glenn
  • Benjamin Steiner
    November 23, 2015 at 12:07 am
    Bumping this thread.
    I auto-synced audio with video based on timecode, how do I get to automatically use the corresponding synced audio file when playing the video in the timeline?
    In the Media tab, it works: the corresponding synced audio file plays automatically when playing the video.
    But not in the Edit tab.
    Benjamin
    (in DaVinci 12.1)
