Activity Forums Apple Final Cut Pro Sync video clips to audio master track
  • Sync video clips to audio master track
    Posted by Niklas Lagstrom on December 21, 2011 at 9:35 pm
    Hi.
    I am about to record a music video and need to know the best way to edit it in FCPX.
    This is what I want to do:
    1. Record multiple takes with audio on set going into my 5dmk2 mic
    2. Import all takes to FCPX and also a Audio master track
    3. Sync all the clips to the master audio track
    and the be able to pick the pieces I need in edit
    Is this possible in fcpx?
    If not, how would you have done it?
    Thankful for advice.
    /Niklas
    T. Payton replied 14 years, 8 months ago 2 Members · 1 Reply
  • T. Payton
    December 22, 2011 at 10:21 pm
    This should work just find with FCP X regular syncing. Just select all your clips and sync. If not PluralEyes (currently in beta) can pull it off.
    However, shooting a music is a little tricky, and syncing is probably the least of your worries. I haven’t done it myself, but I would recommend you conduct many tests to ensure you workflow is solid before brining in the talent.
    T. Payton
    OneCreative, Albuquerque
