Activity Forums Adobe Premiere Pro Sync to subclip not working
  • Sync to subclip not working
    Posted by Justin Crowell on November 12, 2013 at 9:06 pm
    Hi all,
    I’ve seen similar notes on here about what may be a bug, but I just want to see if I’m missing something. My workflow:
    1) Import video and 2nd system audio
    2) Drop all in a timeline and sync with PluralEyes (just seems to work a lot better with single cam/in-cam audio and single recorder)
    3) cut up sequence that came back from pluraleyes, delete unused audio tracks and sections. Link in-cam and recorder audio. (all linked audio and video are made the same length)
    4) Doubleclick newly linked clips to open individually in source viewer, cmd+u to make subclip
    5) After all subclips made, open each one in viewer to break down into subclips based on takes
    Issues: It seemed to work for a while, but now premiere is starting each subclip at 0:00 of the clip from which it came. It is using the correct duration, but wrong starting point.
    Premiere also adds back in the audio tracks that I deleted.
    Any thoughts? I’m reluctantly to leave subclipping behind…it’s too useful!
    Editor, Producer, DP
    JustinCrowell.com
    Justin Crowell replied 12 years, 9 months ago 1 Member · 1 Reply
  • Justin Crowell
    November 14, 2013 at 3:45 pm
    So….judging by the icy response, no one else has run into this or it’s just a bug?
    JustinCrowell.com
