  • Posted by Karim Cherif on February 23, 2009 at 8:01 pm
    Hey Peeps,
    I’m using Sounds keys to distill data between -1 & 1. And I would like that to Time Remapping. Basically I would like it to move according to the track, jumping forward and backwards according to the beat.
    Falloff is none. Not sure if that’s right…
    But what was the expression in Time Remapping to get this to work?
    Tnx
    Karim Cherif replied 17 years, 7 months ago 2 Members · 3 Replies
  • Kevin Camp
    February 23, 2009 at 9:12 pm
    i think you’d just enable time remapping for the footage layer, add and expression to time remapping, create a variable to hold the audio level data and a little equation for how you want it to react with current time…
    it might look a bit like this:
    m = 1; // this is a multiplier to fine tune how the levels react to the time. adjust to suit
    n = thisComp.layer(“audiolevels”); // use expression pickwhip to direct to audio values
    farmesToTime(timeToFrames-(m*n))
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Kevin Camp
    February 23, 2009 at 9:27 pm
    oops, that last line had two mistakes… it should look more like this:
    framesToTime(timeToFrames(time)-(m*n))
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Karim Cherif
    February 24, 2009 at 8:24 am
    Thanks for that! Now I can kinda understand what I’m supposed to be doing! 🙂
