Activity › Forums › Avid Media Composer › Sync question for Adrenaline
  • Sync question for Adrenaline
    Posted by Jesenko Fazlagic on November 14, 2007 at 7:45 pm
    I have a PC Adrenaline (2.7.2 on XW8200) that is being fed SD sync off a Evertz 7750SRG card (housed in a Evertz frame). That is a unit that generates HD and SD sync and I have them routed properly to the SD and HD sides of the Adrenaline.
    We are now having issues where the Adrenaline is not behaving properly when set to the external sync, but is fine when set back to the internal. I seem to recall reading or hearing somewhere that Avid needs a true black burst signal to function. Is this correct?
    I have several FCP2/Kona3 systems that are perfectly content with this sync.
    Thanks for any input…
    //Jesenko
    Jon Zanone replied 18 years, 10 months ago 2 Members · 1 Reply
  • Jon Zanone
    November 15, 2007 at 12:02 pm
    Are you feeding your sources (decks, etc.) with the same sync? As long as the signal is 1V peak to peak you should be good to go.
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
