Activity › Forums › Apple Final Cut Pro Legacy › sync problems
  • Jerry Hofmann
    June 13, 2005 at 2:18 pm
    How are you monitoring the audio and video in determining this? i.e. is there a capture card involved? Using computer speakers or external speakers with an external video monitor or?
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Accountclosed
    June 13, 2005 at 3:00 pm
    i’m using an external pal monitor and external speakers as well the canvas and viewer. there are several other factors: i did the orginal edit on a g4 with 4.5. i’m re-editing on a g5 with 4.5 and tiger. also the original timeline started at 01 with drop frames and the re-edit start at 10 without drop frames.
  • Jerry Hofmann
    June 13, 2005 at 5:40 pm
    There is an offset for playback in the A/V settings’ Playback Control Tab. Might try adjusting that until the material comes into sync.
    Jerry
  • Gunner Jones
    June 13, 2005 at 6:16 pm
    Make certain that your speakers and monitor are connected to the DV Deck and NOT the Mac.
    O&O-Gunner Productions
    FCP-Avid-After Effects
  • Accountclosed
    June 14, 2005 at 1:25 pm
    thanks for your help on this. it reminas unsolved.
    the frame offset is set to 4. i assume this is the default setting as i haven’t changed it. but i don’t understand why there is a standard frame offset on playback?
    do you think my changing the timeline counter will have made any difference?
