Activity Forums Adobe Premiere Pro Sync problems using Capture in CS6 PP
  • Sync problems using Capture in CS6 PP
    Posted by Dave Morrison on January 27, 2013 at 4:05 am
    I was given several VHS tapes to capture using PP 6.0.2. This setup has worked fine in the past, but this time the captures are WAY out of sync. The video will be ahead of the sound by as much as a second or more. I have done short 5-10 sec. test captures and they too will fail with the same problem. I’m capturing into NTSC 8-bit, DV/DVCPRO codec which has proven rock solid in the past. My interface is the Matrox MXO2 and I’m on OS 10.8.2 capturing into an 8-bay RAID drive. Any ideas? I’m not sure whether to blame this on my Matrox unit or on PP.
    Dave Morrison replied 13 years, 7 months ago 2 Members · 2 Replies
