Activity Forums Apple Final Cut Pro Legacy Sync Problems Capturing
  • Sync Problems Capturing
    Posted by Rory Keenan on March 25, 2009 at 12:21 am
    I’m capturing some old VHS footage through an AJA IO HD box.
    The footage is coming in completely out of sync . . . Any suggestions??
    The sync seems to be slipping as the clip is played.
    I put it in a sequence and shifted the audio and video 1:14 and it synched perfectly at the top of the clip . . . .but if i skipped to the end of the clip it was out of sync again.
    I tried capturing with the “play back offset” in the “System settings” changed to 3 different settings . . . . first 1 then 0 then 4.
    Any Suggestions????
    Rory Keenan replied 17 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
