Activity Forums Apple Final Cut Pro Legacy Sync Problems Capturing AJA IO HD box
  • Sync Problems Capturing AJA IO HD box
    Posted by Rory Keenan on March 23, 2009 at 10:45 pm
    I’m capturing some old VHS footage through an AJA IO HD box.
    The footage is coming in completely out of sync . . . Any suggestions??
    The sync seems to be slipping as the clip is played.
    I put it in a sequence and shifted the audio and video 1:14 and it synched perfectly at the top of the clip . . . .but if i skipped to the end of the clip it was out of sync again.
    I tried capturing with the “play back offset” in the “System settings” changed to 3 different settings . . . . first 1 then 0 then 4.
    Any Suggestions????
    Rory Keenan replied 17 years, 5 months ago 2 Members · 4 Replies
  • Jeremy Garchow
    March 23, 2009 at 11:09 pm
    Open the Quicktime file and watch it in the Player. Is the quicktime file out of sync?
  • Rory Keenan
    March 24, 2009 at 12:38 am
    The Quicktimes have the same sync problems
  • Jeremy Garchow
    March 24, 2009 at 1:29 am
    Sounds like you need to recapture.
    Perhaps your ioHD was setup incorrectly?
  • Rory Keenan
    March 24, 2009 at 9:59 pm
    I can re-capture if necessary (no problem)
    But unless I figure out the right settings the re-capture will have the same problem.
    My question is:
    What is causing this problem so I can fix it for the re-capture????
    I think it may be something in the “System Settings” like “frame offset”, but I’m not sure.
    Does anyone have any idea on what to try
    (the AJA IO?HD box is a piece of hardware . . .there’s not many settings on it . . . . however there is an “AJA control panel” application . . . . . does anyone have any suggestions for settings in the AJA control panel???? . . . . .would the AJA control panel even make any difference with synch??)
