Activity Forums Blackmagic Design Sync problem with Decklink Extreme under Windows
  • Sync problem with Decklink Extreme under Windows
    Posted by Joerg_cologne on June 13, 2006 at 9:09 am
    Hi
    I have the following problem and hopefully someone has a hint for me 🙂
    A new machine mit Windows XP Pro SP2
    Decklink Extreme
    Grass Valley PAL component mixer
    Blackburst Generator
    DirectX 9.0c
    newest Quicktime (I use the free version at this time for testing)
    I want to present a powerpoint-presentation to the component-mixer.
    If i connect the decklink to a monitor (no sync needed) everything is fine but if I connect the Decklink to the videomixer the picture is not stable.
    Normally if i connect the genlock the picture will be stable in a few seconds. But it seams that the card still doesn
    Joerg_cologne replied 20 years, 3 months ago 1 Member · 1 Reply
  • Joerg_cologne
    June 14, 2006 at 1:29 am
    Yippppiieeee
    Andrew from BMD gave me the hint that fixed my problem.
    First I found out, that the signal is NOT PAL – it was NTSC.
    Andrew pointed me to the correct setting and know it works great ;-))
    Cheers
    Joerg
