Activity › Forums › Apple Final Cut Pro Legacy › Sync problem on export
  • Sync problem on export
    Posted by Jonathan Griffiths on February 18, 2013 at 8:10 pm
    I have a Proress timeline which plays fine with in FCP but when I export Quicktime one shot goes out of sync when I playback in Quicktime player the rest of timeline is fine. But if I re-import it it is fine in FCP. I have tried to recompress but it same result any surgestions gladly appreciated
    Jonathan
    Jonathan Griffiths replied 13 years, 7 months ago 2 Members · 4 Replies
  • Nick Meyers
    February 18, 2013 at 10:58 pm
    what format is the problem shot?
    maybe it’s a non-FCP standard format like H264.
    thy can be unpredictably tricky.
    if that’s the case, then export or convert that shot, and re-inert it,
    then try exporting.
    nick
  • Jonathan Griffiths
    February 19, 2013 at 11:43 am
    The shot in question is ProRes as is most of the sequence there are a few ProRes HQ 25fps and Pal-DV 25fps shots later in sequence but everything up to this point is full HD ProRes 25fps
  • Nick Meyers
    February 19, 2013 at 12:12 pm
    ok, this reminds me of something i had a few years ago where the file did not have a stable TC track.
    within FCP sync was fine, any export from a timeline was out.
    the solution *from memory* was to batch export the clips, (same settings, self contained)
    or maybe Media Manage them using Copy.
    sorry i can’t be more precise.
    anyway the new files had an OK TC track, and would export properly
    the problem started with a not so great “capture now” process direct from a telecine chain.
    hope that helps
    February 19, 2013 at 12:39 pm
    Thanks for help we made another clip from the part we used shifted it by 5 frames exported as new QT re-imported problem solved but I am sure you are right about it being TC problem.
    once again thanks
    Joanthan
