Activity Forums Apple Final Cut Pro Legacy Sync Problem
  • Posted by Patrick Morrow on November 24, 2005 at 6:59 pm
    Why is it that when I copy a project to DVD the audio is right on but when I play off the timeline to a DVD burner it most often lags behing by almost a second?
    IT DOES THIS AFTER IT HAS BEEN PLAYING A WHILE AND NOT RIGHT FROM THE START. PLEASE ADVISE AS I LIKE TO MAJE A COPY OF THE PROJECT STRAIHJT TO DVD MEDIA.
    THANKS!!!
    PATRICK MORROW
    Thaxter Clavemarlton replied 20 years, 10 months ago 2 Members · 2 Replies
  • Thaxter Clavemarlton
    November 25, 2005 at 12:53 pm
    There is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
    You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
    NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    You should see a dialog box telling you its rendering.
    It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
    NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
    November 25, 2005 at 1:00 pm
    You did not say what kind of Mac, how much RAM, what kind of Hard Drives, or what version of FCP. If you want more complete ANSWERS, you need to provide more complete QUESTIONS.
    FWIW,
    External FW Hard Drives are notorious for not being able to “keep up” with a sustained video/audio recording or playback. That’s why they are not “officially sanctioned” to operate with FCP.
    Regardless, the MIXDOWN that I described should help you.
