Activity Forums Apple Final Cut Pro Legacy Sync Problem
  • Posted by Hiptv Llc on September 30, 2005 at 2:49 pm
    We have a final cut pro 5 with the Aja Kona II board. Since we are still mostly an analog shop, we are converting the SDI signal in and out of the box through a ProMax converter made by Convergent Design. The problem is that on playback sound and image will randomly go out of sync. We can not figure out why this happens, but if we close and re-open final cut, it solves the problem, at least till it starts happening again. This happens every day, often multiple times. We have loaded the latest drivers for the Kona II, but it gave us no satisfaction. Has anybody else experienced this? Is there a solution?
    Brian
    Jerry Hofmann replied 20 years, 11 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    September 30, 2005 at 5:52 pm
    FWIW, I capture Beta SP all the time thru my Kona2 card without these problems, but am using AJA’s mini converter to do it… might be the fix, dunno… https://www.aja.com/d10a.htm Audio is coming in from the Kbox…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
